  1. 2 quick questions on file formats
    What is the format of vob files on a dvd? m2v, mpeg2, mpeg4?
    Same question for vcds? Thanks Wayne.
    If the Thunder don't get you, the Lightning will!
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    DVDs are MPEG2
    VCDs are MPEG1
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    per the glossary:
    MPEG-1
    An ISO/IEC (International Organization for Standardization/ International Electrotechnical Commission) standard for medium quality and medium bitrate video and audio compression. It allows video to be compressed by the ratios in the range of 50:1 to 100:1, depending on image sequence type and desired quality. The encoded data rate is targeted at 1.5Mb/s - this was a reasonable transfer rate of a double-speed CD-ROM player (including audio and video). VHS-quality playback is expected from this level of compression. The Motion Picture Expert Group (MPEG) also established the MPEG-2 standard for high-quality video playback at a higher data rates. MPEG-1 is used in encoding video for VCD. MPEG FAQ
    MPEG-2
    An encoding standard designed as an extension of the MPEG-1 international standard for digital compression of audio and video signals. MPEG-1 was designed to code progressively scanned video at bit rates up to about 1.5 Mbit/s for applications such as CD-i. MPEG-2 is directed at broadcast formats at higher data rates; it provides increased support for efficiently coding interlaced video, supports a wide range of bit rates and provides for multichannel surround sound coding such as PCM, Dolby Digital, DTS and MPEG audio.
    MPEG-3
    A proposed variant of the MPEG video and audio compression algorithm and file format. MPEG-3 was intended as an extension of MPEG-2 to cater for HDTV but was eventually merged intoMPEG-2.
    MPEG-3 should not be confused with MP3 which is MPEG-1 layer 3 popularly used for audio encoding.
    MPEG-4
    An ISO/IEC standard 14496 developed by the Moving Picture Experts Group (MPEG), the committee that also developed MPEG-1 and MPEG-2. These standards made interactive video on CD-ROM, DVD and Digital Television possible. MPEG-4 is the result of another international effort involving hundreds of researchers and engineers from all over the world. MPEG-4 was finalized in October 1998 and became an International Standard in 1999. The fully backward compatible extensions under the title of MPEG-4 Version 2 were frozen at the end of 1999, to acquire the formal International Standard Status early in 2000. Several extensions were added since and work on some specific work-items is still in progress.
