I've tried all versions of FlaskMPEG but i'm unable to select the Panasonic plugin. Did everthing (so i think) like I should but FlaskMPEG can't find the plugin. What am I doing wrong?? Plz help.
Results 1 to 9 of 9
Have a look at the docs, that came with FlaskMPEG.
Install the plugin, copy it from Premiere plugin directory to the FlasK directory and rename it. -
Tried that Truman but during install I get an error message saying;
An error occured during the move data process: -145
Component: plug-in files
File group: plug-in DLL
File:
And then it stops.. You know what this means?? -
Well, but it makes life easier, when you install the plugin.
You'll receive a PM soon... -
Cybergnarf,
Did you get that error when you where installing the Panasonic MPEG plug-in? If so, it means that it didn't install properly...
All you need to do is to create a dummy directly where Adobe Premiere plug-ins normally sit (e.g., C:\Program Files\Adobe\Premiere 5.5\Plug-ins ).
Regards.
Michael Tam
w: Morsels of Evidence -
I was having the same problem...so then I installed the latest 2.5 demo....THEN I installed my full version 2.1 plug-in....didn't get the error this time and installed correctly. What the 2.5 demo had to do with it, I have no idea.
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 08:30 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 20:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 17:15 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 12:37
