Hello, I have made around 43 orginal Audio CDs to MP3 and then I burned it on a DVD. But I canīt play it on the DVD player ( not a PC DVD ), so I wonder if anyone can help me how to put music on a DVD and play it like a CDr whit MP3.
Because a CDr whit MP3 works, while the DVD canīt be found. I very recently began using a DVD burner. I using RecordMax and Nero.
Thanks tomaz.
Results 1 to 11 of 11
Best Regards tomaz.
Not all dvd players supports dvdmp3. Check the dvd players too see if anyone have reported that it works.
Ok, thanks. But is there any simlar format to MP3 use otherwise?
Best Regards tomaz. -
Get yourself an AC-3 encoder and encode as AC3. Sounds pretty good in my opinion. All DVD-players should be capable of playing back AC-3 encoded audio, or you could let your AV-reciever decode it for you.Originally Posted by tomaz
/C -
Try this guide:
https://www.videohelp.com/forum/viewtopic.php?t=183467&highlight=
It will allow you to select an mp3 as an asset, it will convert the audio to ac-3, and author to dvd standards. -
See also this guide and user comments: https://www.videohelp.com/forum/userguides/193049.php
You can use free dbPowerAmp (with file browser plugin and mp2 codec) to batch convert mp3 to mp2 or rip cds direct to mp2 or PCM.
With audio files in place, you use TMPGEnc Encoder to create low bitrate still or blank images to go along with the audio.
Finally, TMPGEnc DVD author is used to create menus for each album where each album is a dvd track, and each album track is a dvd chapter on that track.
Works great! -
Thanks, keep sending ides. Iīll try some of this tips, and get back here to tell about it.
Try Audio DVD Creator. It'll make a music DVD that your player will actually like.
tomaz: maybe if you tried the link a few months earlier...
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 16:13 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Mp3 to Mp3? Audio Compresstion / Down sampling?
By YuJay in forum AudioReplies: 7Last Post: 7th Dec 2008, 12:05 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 25th Aug 2008, 23:59
