When Iīm done cutting my movie in Premiere Pro the audio always get out of sync.
I cut using "CTRL+K" in the timeline and then "Ripple delete" on the part that I donīt want to be left.
Is there another way to cut in Premiere Pro, that doesnīt leave my audio out of sync?
You didn't say what kind of Audio it was? I suspect it may be VBR?
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Itīs just an AVI direct from my DV camera... Captured in Premiere Pro.
Not sure about the VBR... -
Originally Posted by Jonne
I wouldn't have thought editing pure DV files and not doing a format change would cause sync problems thought. But another place to try to ask are the Adobe forums at www.adobe.com
Larry
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
