I have the two towers extended edition, and its 2 dvds just for the movie. I know how to copy something without menus and how to copy something with menus (dvd2one). But how would i go about copying this (i want to put it on one dvd). i figured i'd do the same thing, but before burning, i'd merge the vob files somehow, or something. any tips?
also, is dvd2one the easiest/fastest software to use for this job and similar ones (cause if its not i'm going to get something else).
I did this exact thing and I used DVD2one and although I thought it would look like crap, I was wrong, it came out pretty damn good.
I ripped both DVDs with DVDDecrypter.
I stripped the subs and audio not wanted with ifoedit.
joined with DVD2one.
Burned with BurnAtOnce.
Viewed with PS2, PowerDVD, Pioneer settop box.
Came out better than expected... There are other ways of doing this but this method was quick and painless. Good luck.-=[ JHMac ]=-
Experience is something you don't get until just after you need it. -
The latest version of DVD2ONE has this new "join" function. It will join 2 discs and not the VOB files as such, just decrypt both discs to your hard drive and away you go.
Avatar Extended Edition forced subtitles issue with RipBot264
By DrPreston in forum SubtitleReplies: 16Last Post: 24th May 2013, 17:51 -
Joining two m2ts-files from two blu-rays (LOTR extended edition)
By NTC1985 in forum Video ConversionReplies: 6Last Post: 28th Aug 2011, 18:44 -
Newb Help Please - LOTR Extended Edition
By dpend in forum Blu-ray RippingReplies: 7Last Post: 5th Jul 2011, 13:21 -
Extended characters
By Jomapil in forum ComputerReplies: 3Last Post: 6th Apr 2010, 14:40 -
Extended warranties on TVs
By samijubal in forum DVB / IPTVReplies: 24Last Post: 5th Jul 2007, 12:30
