I have a movie that i'm trying to back up... I did the dvd2one thing, and downsized it without menus. When i play it on my computer using the ATI DVD player it works fine. but when i play it on my standalone (philips dvd-711 i believe..) it plays black and white, and like the picture is dropped down 1/3 of the way... did i burn it wrong? Any suggestions as to why it doesn't play properly?
It sounds like you have an encoding problem in that you're trying to play an NTSC movie on a PAL TV that won't handle NTSC (or the revese). The symptoms are much the same as what you are experiencing.
Computers don't care which type of DVD it is as they all handle both but TV sets do care altough most modern PAL TV's will also accept NTSC but very few NTSC sets will take PAL encoding.Artificial intelligence is no match for natural stupidity. -
so how do i fix it? how do i re-encode a vob file to coincide with my tv's settings (i know my tv is ntsc)?? I'll check the guide section to see if they explain it but i'll ask anyways so in case there isn't a guide somebody may answer me in advance... thanks a lot
Converting from PAL to NTSC is a long process so first check that I'm right. Take a look at the original DVD and see if it *is* PAL encoded or states Region 2 or one of the other PAL regions.
If it does there is various guides on this site that will walk you through the process of conversion. Good luck!Artificial intelligence is no match for natural stupidity.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 22:56 -
a/v sync - computer plays ok, pmp not
By adom in forum Video ConversionReplies: 3Last Post: 20th Mar 2011, 06:19 -
BetaMax plays fine for a while then bad picture
By LSchafroth in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2010, 21:31 -
Canon widescreen plays 4:3 on computer
By yurkyurk in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 10th Jan 2008, 06:06 -
VHS plays fine on TV, bad when captured...
By rachel.twu in forum Capturing and VCRReplies: 15Last Post: 10th Jun 2007, 00:38
