  1. i've looked high and low for karaoke cd playing software but i cant find crap.
    i know there is plenty of software to backup karaoke (cd+g) discs, but software to play it on your computer seems non-existant.
    i've tried windvd & powerdvd, but those only play karaoke dvd's.
    anyone have or know where i can get a program to play karaoke cd's on my PC?
    thanks for any help anyone can provide
    Mar 2003
    Dunno if this will help but try this
    http://www.vanbasco.com/
    or
    this
    http://www.mtu.com/basics/karaoke.htm
  3. the vanbasco thing is the same crap that is available in every other package..
    but the mtu thing looks like it will actually play a karaoke cd.. there is a demo that will play the first 75 seconds of a song, so that will be good enough to test if the backups work..
    a friend of mine sent me a bunch of karaoke cd's and asked me if i would back them up for him.
    i'll have to wait til i get home to try it out, but thanks for your help none the less.
    Mar 2003
    I thought the fisrt one was for mp3 or midi kareoke files but I figured the second one might work for you.
    Quick question do need a specific cd writer or can use use just about any of them that can work with software such as clone cd or alcohol 120% to make copies of Karaoke cd's
  5. well i tried the karaoke software on 2 different computers with drives that were supposedly "karaoke compatible".. tried both an original & a copy.. neither of them would display any on-screen graphics.. one would play music, the other would not..
    i made the copy with alcohol 120% (there is even a cd+g profile).. i'll probably know if the backups work this weekend.
    Apr 2002
    Los Angeles
    well...... i currently use the Karaoke Builder CD+G Player to play my karaoke files (cd+g & mp3) that i download from the internet.....yet i dont think my dvd-rom actually reads karaoke discs .Nevertheless, i am able to burn downloaded karaoke files (cd+g & mp3 encoded into BIN format) to cds with cdrwin, which play fine in any karaoke machine.
    anyways the website for the player and other tools is http://www.karaokebuilder.com/ , i hope you find what your looking for.
