Hi
Trying to compile a music dvd of some of my old tapes with a couple of tracks off my dvds
1- got the laser disk and tape fomats great for ULEAD movie factory using capture in VideoSTUDIO
2-Extracted the dvd files I wanted to mix in the compialtion
BUT BUT I cant get the vob files into Movie factory
Anyone help
Which programme would I use to convert the vob data to mpeg2 data
And Factory Doent want ac3 sound files - phew !!!
So I ave 5 Laser disk files OK
4 Tape files Ok
and 2 dvd files sadly not OK at this moment BUT I m quite certain
that one of you will easily help out and then I'll say "Why Didnt I think of that?"
Regards guyz and galz in anticipation of a quick reponse
Results 1 to 9 of 9
Or...after coping the .vob files to your hard drive, change the .vob extension to a .mpg extension. Then see if if you can import the new .mpg files into Movie Factory. I've been able to do this using Studio 8.
Geronimo -
The most efficient way is to load the VOB in Virtual Dub mod, then either save it as an AVI, or framserve it to TMPGEnc to encode it as an MPEG.
Hello. -
- one way is to demux your video and audio streams using VOBEdit and then multiplex them using TMPEnc.
- another way is to use TMPGEnc DVD Author (30 day trial available) to wite the mpg to your hard drive after importing DVD video.
Hope this helps
P.S. I did get MovieFactory 2 to pass thru AC3 sound by changing a line item in the .ini.
Good luck!In XP, look in C:\Documents and Settings\All Users\Application Data\Ulead
Systems\Ulead DVD Movie Factory\2.01
Open DVDMF.ini in notepad and edit "PlayAC3=0" to "PlayAC3=1"
I know that works in dvd workshop. I haven't really tried it in Movie
Factory, it might work like some has said here.
Also, you'll have to multiplex the AC3 with mpeg since ulead doesn't accept
streams. -
Hey
Thanx guyz
I knew i would et all the help needed on this forum
Its much appreciated
regards to you all and obviously
A Very Merry Xmas
open the vob files up in windows media player and save the as xxxx.mpg
this only works on the old versions of windows media let me no if it worked
Converting .VOB files to MPEG4 with Streamclip and MPEG2 Playback Component
By MLK3329 in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 13:51 -
Machine-gun audio in avidemux for mpeg2/vob files
By resloan in forum EditingReplies: 2Last Post: 26th Jan 2011, 18:39 -
DVD (VOB) files to mpeg2
By maxamillion in forum DVD RippingReplies: 7Last Post: 17th Dec 2008, 23:37 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
Hi
