I've recently started having a lot of problems getting my DVD burner to burn data disks (for some reason, I haven't had trouble w/ the last few ISOs I've burned -- perhaps it was because they were smaller?)..
The error is:
Error -10 at Sector 2192256 - Disc Write Error - Command:2A Sense:03 ASC:0CASCQ:08 (error it gave for my last try w/ Accu media) -- waited till near the end of the burn. It just gave me: "Error -10 at Sector 102032 - Command:2A Sense:05 ASC:21 ASCQ:02" when I tried w/ a DVD+RW disc (it died quickly) When I try it in Nero, the error says "Invalid Block Address" (more @ bottom of message)
I have a Sony DRU-500A. I just tried upgrading from 1.0F to 2.0G to see if a firmware update would make a difference.
The same media (ACCU) burns fine on my GF's Polaroid burner and has been working for me for a while..
I've tried burning at 1X and 2X - same problem. I also tried burning using Nero instead of Recordnow and it also failed.
Also, I have a strange problem where Win XP doesn't always detect it when I put disks in the drive. Rebooting will fix it. What is strange if I run the "media info" section of one of the burners or even the disk manager in XP, it can tell that there is a disk in. I don't know if it has something to do w/ not coming back alive after a suspend...
Nero log:
6:20:07 PM #20 SCSI -1064 File Cdrdrv.cpp, Line 1402
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02F30000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x01 0x8E 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x05 0xFF 0xFE 0x86 0xB0 0x12
0x00 0x00 0x00 0x00 0x21 0x02
6:20:07 PM #21 DVDR -1064 File Writer.cpp, Line 331
Invalid block address
Nero isn't the most stable of programs, I've discovered. You could check the FAQ on the Nero site. They have had plenty of issues.
Your problem may already be posted.
I would completely uninstall nero. After uninstalling from "add remove programs" I would do a search for Nero and remove everything you find. Also search the registry for Nero/Ahead, and remove as well. Then reinstall Nero. -
I found some info @ google posted by someone else having similar problems. I ran an application called "nero-cleantool" and then downloaded the latest Nero from the site. I am now able to burn w/ Nero. I haven't tried it again w/ Recordnow -- but maybe there was some sort of a DLL issue?...
I mailed with Recornow staff about error -10, they said it can be buffer underrun or crappy media. in my case it was crappy media.
Hope this helps -
I think I've had steppin_razor's same problem, where near the end of the burn Nero consistently (every DVD) gave errors starting with "Invalid Block Address".
I tried reinstalling Nero, using the "nero-cleantool" app, AND removing anything w/ Nero or Ahead from the registry -- none of it worked for me.
Here's what did work: System Restore (WinXP). I restored past a point where I'd installed InstantCopy version 8.0.3, so that may well be what had started the problem.
BTW, one way to get to it is Startmenu --> Accessories --> System Tools.
Cheers.
DVD failing to write
By misha1123 in forum DVD & Blu-ray WritersReplies: 7Last Post: 31st Aug 2010, 07:07 -
DVD Burnings Keep Failing
By spike32 in forum MediaReplies: 10Last Post: 15th Sep 2008, 12:43 -
Dvd burner keeps failing
By red69 in forum Authoring (DVD)Replies: 8Last Post: 8th Nov 2007, 19:31 -
Burning Failing in Nero 7
By Osaka in forum Newbie / General discussionsReplies: 11Last Post: 10th Sep 2007, 15:03 -
Newbie Burning Failing
By mearm in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2007, 04:40
