to start with: hello everyone
now to my problem, the player works ok, everything is fine, its being hooked to a Sony Wega tv.
the tv is set either AUTO or PAL
the dvd, when played gives a black and white image, no matter what i do, when inserting a pal disc i get it bw
i heard on some players it would be needed to force the player to play on NTSC, but still, the player switches itself back to pal, and thus, i get a bw image (even choosing the NTSC setup)
its really weird since the dvd is supposed to play pal and ntsc discs.
my country's tv signal is PAL so i know the tv is working correctly.
ive tried both dvd outputs, the composite and s-video. no luck.
tried different tv inputs, 2 different tvs, both pal/ntsc capable..
so, anything you guys know i should do? (other than buying another player)
could there be a firmware upgrade im missing? i couldnt find one.
thanks in advance
Results 1 to 1 of 1
DVD Playing issues
By guessrpm in forum MediaReplies: 9Last Post: 6th Mar 2010, 08:44 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
Back up playing issues
By mo1136 in forum DVD RippingReplies: 3Last Post: 11th Jan 2009, 22:23 -
Any long term issues with playing dvds on a side-mounted desktop tower?
By yoda313 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Nov 2008, 10:59 -
.ts file playing issues
By schmoppa in forum Software PlayingReplies: 3Last Post: 10th May 2007, 19:58
