Hi all!
Which encoder is the the best when converting DVD to SVCD, CCE or TMPGEnc?
lillara
Some prefer CCE, but I like TMPGEnc which has always gotten me better quality results. It's a matter of personal preference though. There really is no "better".
There is no best encoder for anything. Its like asking what the best color is, its entirely subjective.
What can be said objectively is that CCE is much faster than TMPGenc. On the average pc CCE is anywhere from twice as fast to literally 4 times faster. CCE definitely has a steeper learning curve and may require you to do more preparation for your source before you are ready to encode. For instance, if you need to do any resizing you are going to have to do that before using CCE. TMPGenc has many more built in features and filters, and it supports program stream tools, ie: cut/join/mux/demux etc... Its more of an all in one program, whereas CCE is just a bare bones encoder.
Both encoders are extremely high quality, and either will produce stellar SVCDs.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 08:46 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
....... I´ve been over it again and agin and can´t find the problem... Any suggestions?
