    Sep 2003
    Big Apple
    Can someone recomend a good dvd copying program. I heard DVD Copy X is the best, but it can't copy menus.Are there programs that can make exact copies of dvd including the menus.
  2. DVD SHRINK is great, and even better it is free, it will copy working menus and extras, unless of course you try to reauthor. If you reauthor the menu will not function.
    Sep 2003
    Big Apple
    What does it mean to reauther?
  4. What does it mean to reauther?
    you can read about it in one of the guide to the left. in the meantime if you want FUNCTIONAL menus using DVD Shrink do not press that pretty little button the says Re-Author. just press Back-Up.
  5. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    @slimmx, it's best you check your DVD structure first if you can as sometimes the movie VTS will contain more than just the movie
    @noki, just an update question, does it now start with menu or do you still need to mod the IFO?
