I wanted to know if there is a way to removing two Black bands from the top and bottom of a VCD???
Results 1 to 10 of 10
You can crop your video when encoding to vcd. Instructions will depend on the program you use.
Alfonso -
those programs are for burning......reencode your vcd using tmpg and in the settings tab-->advanced...there is a setting to crop the picture which is called "clip frame"....
use TMPGEnc, it has a full screen option that crops off the sides when encoding
You might want to do a little research and learn *what* "those little black bands" are.
Personally, I like widescreen, but I do not want to start a WS/PS debate...
Do research, and decide for yourself...
dp -
As what loudanddeep said widescreen does have its purpose and most people actually prefer the format since it preserves the original vision of the director.
But this is more than just a Widescreen vs fullscreen debate because if you simply crop the top and sides the picture will fill the screen but it will be far from a proper pan and scan movie. When you crop the sides you lose parts of the picture. When this is done professionally they scroll through every frame and pan side to side to get all the important parts and zoom in and out to get it all to fit. If you just crop without doing the proper panning and scanning than you will lose important parts of the picture.
It really ruins the movie when characters are talking and they're not even on the screen.
You can do a pan and scan yourself but its very time consuming and would definitley be more trouble than its worth, even if you do prefer PS over WS. -
I too would like to watch full screen movies. I tried "clip frame" and some other things such as "full screen keep aspect ratio 2" which sounds like it should do it. But neither worked at least when viewed in Media Player. Do you have to wait until after its burned to see it in full screen?
- Use DVD2AVI
- At menu bar , select VIDEO , Option Clip & Resize
- Go to a bright frame of the movie and adjust your cropping
<font size=-1>[ This Message was edited by: alb1n0 on 2001-10-15 21:00:14 ]</font>
When 16:9 isnt 16:9. Black bands top and bottom.
By agoldfish in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2011, 11:18 -
Question - Black bands on top and bottom of the screen. (16:9 TV)
By Rainbow1962 in forum Newbie / General discussionsReplies: 31Last Post: 16th Jul 2009, 01:45 -
Black borders at the top and bottom of Video
By Maikeru-sama in forum Video ConversionReplies: 7Last Post: 23rd Jul 2008, 20:21 -
Need to remove black lines top/bottom
By Verlager in forum LinuxReplies: 23Last Post: 29th May 2008, 07:39 -
Why do some Widescreen Movies still have black bars top and bottom?
By the_importer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Dec 2007, 09:09
