Hello all:
i am really getting frustrated with some conversion problems i am having.
I have a few episodes of a show that rhymes with "astlane" that i got from the usuall sources.
I have tried to convert with Avi@VCD, and of course i need to decompress the audio before i can convert it. So, when i run the decompressed video file through avi@VCD, i get some tricky problems. The video will be fine for the first few frames, and then the video will freeze and the audio will continue.
I have tried running the avi file through tmpgenc, and i am told that it is unsupported. I have tried running the mpg file (that was generated from avi2VCD) through tmpgenc, and the video turns out slightly better....but extremly choppy (like a frame every 15-20 seconds).
I have also tried to change the heading with AVIC....and i have not been able to find a working combination. Additionally, running the original video files (unaltered through avic, results in a "unknown converter for DX50 in virtualdub) When i change the header into with AVIC, i can get the file to laod with virtualdub....but it will not display the video (it says, error 100)
could anyone please let me know what i have to do to convert these files to svcd? thanks so much!
(yes, i have nemo codec pack installed)
-Lou binetti
whyming with astlane=unnecessary information. you'll get better results here just asking your q:
Anyho, load the file in virtualdub then click file>file information
What type of deocmpressor is it using, and what kind of audio?
this info will help.
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 04:44 -
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 08:54 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 20:45 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 05:51 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 08:36
