Results 1 to 21 of 21
    7th layer of hell
    for some unknown bizarre reason quicktime mpeg-2 decoder just flat out stopped working for me... it was working fine yesterday and i havent changed thing since then.... its 6.4 on 10.3.1 and i have never ahd a problem with it till today... i tried deleting the componenet and the reciept and reinstalling to no avail... has anyone else had any similiar problems or suggestions on what to do??? this is soooo weird... thankx
    As below, so above and beyond, I imagine
    drawn outside the lines of reason.
    Push the envelope. Watch it bend.
    Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
  2. You're not alone. Here's a poost from the Macintouch web site:
    "Paul Hughes describes a timeout problem with Apple's QuickTime MPEG component:
    It appears the updated MPEG-2 playback component that Apple provided for QT 6.4 has a timeout. As of 12:10:01 a.m. December 15 I can no longer play back MPEG-2 files under either Panther or jaguar with QT 6.4. The QT discussion board at Apple has lots of other reports of this phenomenon. This renders DVD Studio Pro 2 all but useless and will also affect a lot of other video production workflows, unless Apple fixes the problem fast. So far nothing via Software Update or the QuickTime updater. "
    Jul 2001
    usa
    yeah it sucks big time, it sounds like its across the board on people having problems with this.
    pants on, pants off, pants the floor.
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    agreed.
    just talked with several of my compadres... everyone is experiencing it.
    7th layer of hell
    thanks for the fast responses guys.. that majorly sucks.. why in the world would apple do that?!?!? oh well... i guess i'll have to wait for an update before i can play my mpeg-2 files in quicktime again... that sucks so bad.
  6. Yes, I just updated to 10.3.1 today and now it doesn't work. I deleted it and reinstalled, but no luck. Way to go Apple.
  7. Member galactica's Avatar
    Jan 2003
    aparently if you go back to the old one it will work.. but who knows
    or you can try bumping your date and time back a few days maybe that will help....
    7th layer of hell
    unfortunately (i know i spoke to u about this briefly) you need to go back to quicktime 6.3 to get the older mpeg-2 decoder to work... it doesnt work in 6.4 hence the reason apple needed to update the decoder for 6.4. i dont know if its even possible to downgrade to 6.3 in panther... oh well guess we just have to wait for a fix from apple.
  9. Member galactica's Avatar
    Jan 2003
    too true......
    im sure it will be fixed shortly.
  10. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Macnn has a little bit about it.
    7th layer of hell
    from the apple quicktime discussion forum:
    " All,
    We are aware of this issue and we are investigating. Further information will be forthcoming here, a Knowledge Base document, or both.
    Mark
    Apple Support "
    so i guess we just gotta wait now..
  12. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Reports indicate setting your comp's date back to before the 15th of Dec. will get it working again.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  13. Here's what to do (from tofay's MacIntouch):
    Bruce Yolton explained what Apple is doing to resolve the sudden time-out bug with its MPEG-2 encoding software:
    Although Apple hasn't posted a tech note yet, last night they updated their MPEG-2 software for Quicktime to fix the 12-15-03 expiration bug.
    * To get the updated software, go to the Apple Store, choose review account from the upper right of the store, login, choose Software Download Purchases, and download QT 6 MPEG-2 Playback - Mac OS once again.
    * The new software package will have two folders, "For QuickTime 6.3" and "For QuickTime 6.4 and later". (The outdated software had folders named "QuickTime MPEG2 6.3" and "QuickTime MPEG2 6.4".
  14. And of course (as I just discovered) this does nothing for those who got the plug-in via FCP or DSP. The above only applies to hose who bought the plug-in in the Apple Store. I guess we'll have to wait for a Software update version.
    william
    Dec 2003
    Tried to reinstall 6.3 under X.2.3 no dice, won't even launch. Don't think 6.3 is compatible with Panther.
    If the Thunder don't get you,
    the Lighting will.
  16. Go here:
    http://www.apple.com/quicktime/products/mpeg2playback/download/
    and enter your serial number (FCP or DSP) to get the new mpeg2 plug-in.
    Also OSX 10.3.2 is available.
    william
  17. Oh, and while you're at it, you might as well bite the bullet and download Quicktime 6.5 and iTunes 4.2. Apple must think we all have a lot of bandwidth sitting around with nothing else to do.
    william
  18. If I download QT 6.5 won't my pro number for 6.4 be rendered useless or is that only when they go from say, 5.x to 6.0?
    Strange... I don't see any update for iTunes in my software update. There was an iPhoto one yesterday though, is that what you mean?
    Nov 2003
    Iceland
    I've been using the same sn from 5 to 6.5 no problems :P
  20. Member galactica's Avatar
    Jan 2003
    same, apparently the SN i had for 6.4 also works in 6.5
    maybe its apples way of saying "sorry".....
  21. Member WiseWeasel's Avatar
    Jan 2003
    For iTunes 4.2, you must go here . . .
