Hi, i'm using a Hauppauge wintv pvcr 350 capture card, and wintv 2000 to capture mpeg files to put on dvd, the thing that is happening is that the original captured file is fine audio and video are in sync, but when I author the mpeg file using tmpgenc dvd author or dvdlab the end result is that the audio and video are way out of sync, but if I author it with the software that came with the card which is ulead dvd moviefactory the end result is fine audio and video are in sync. How is this possible, isn't tmpgenc dvd author and dvdlab suppose to be superior software?? Does anyone have any suggestions on how to solve this problem? I would like to use the other software because they have more options than ulead does.
Results 1 to 1 of 1
Confused about Levels
By Smells_Like_Feet in forum RestorationReplies: 2Last Post: 4th Mar 2012, 09:51 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Confused with Encoding
By skorpinok in forum Video ConversionReplies: 3Last Post: 29th Aug 2010, 11:40 -
Ire, still confused.
By aebbeka in forum Capturing and VCRReplies: 15Last Post: 25th Mar 2008, 06:25 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 13:42
