Hi I'm new to dvd-burning... actually I'm before new... I haven't got a burner as of yet. This is where you come in.
I'm considering to buy a Plextor 708A or an LG GSA-4040B. They cost the same (about 180$ here), but the dealer includes 10 Memorex DVD+RW 4x discs with the LG burner (costs about 50$ here).
I'm very uncertain of what drive to select, considering the deal above. I am in urgent need of help, so any responds would be very appreciated.
Thanks in advance
Results 1 to 10 of 10
Let's be realistic and try the impossible!
FYI, the LG GSA-4040B can only write DVD+RW at 2.4X, so getting the 4X DVD+RW discs with the LG model is quite a waste of money. In short, if you need the DVD-RAM function, get the LG. Otherwise get the Plextor since it's a much better DVD writer. There is currently about $60 to $70 difference between these two models, which pretty much reflects the values perceived by the consumers.
Personally I would go for the LG, I've burnt over 60 DVD-r's and some DVD+R and RW with perfect results, unless you want to stick to DVD+R,
which is the only media you can burn at 8x, go for the LG :P
Also DVD+r cost more!. as does the drive. -
Otherwise LG has a new writer out, the GSA-4081B, that supports 8x DVD+R and 4x DVD+RW (the rest of the specs are pretty much the same as the GSA-4040B).
But if you don't need DVD-RAM I would go with the Plextor. -
Thanks guys
Don't quite know why i didn't catch the 4x rw difference.
As I don't really have any particular use for DVD-RAM, I think I'll go get the Plextor, as a nice christmas present for myself.
Oh by the way... Is there any significant difference between the "sub-models", like say Plextor 708A/T3 and 708A/T3K ?Let's be realistic and try the impossible! -
Me too...I have the 4040B and have not had one bad burn...+ or -.Originally Posted by Colindale
The Plextor drive will burn at 8X too. And agreed, if you don't need DVD-RAM, you can't go wrong with it IMHO.Originally Posted by -jsl-
considering the deal still, i'd rather go with the Plex.. I had the LG and had a few problems.
the Plextor which I now have is great! -
Truder wrote:
Plextor has a OEM version of 708A which doesn't include a software bundle. If you can get a OEM version then it's a few dollars cheaper. The bundled software isn't that great anyway so getting a OEM version of it would be fine. There has been talk about some models being different but nothing can be proven as far as I know from reading different Plextor forum sites. Here's a link you can read but it doesn't exactly state that there is a difference between 708A/T3 & 708A/T3K.Oh by the way... Is there any significant difference between the "sub-models", like say Plextor 708A/T3 and 708A/T3K ?
http://club.cdfreaks.com/showthread.php?s=&threadid=80576
Buy the Plextor burner you won't be disappointed.
You can say that again. I havn't used ANY of the crap that came with mine...Originally Posted by budz
Problems with DVD LG GSA-4160B
By Jomapil in forum DVD & Blu-ray WritersReplies: 6Last Post: 11th Feb 2009, 00:33 -
LG GSA H55N region free?
By Ace-Of-Spades in forum DVD & Blu-ray WritersReplies: 2Last Post: 6th Feb 2009, 09:18 -
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jun 2008, 00:50 -
Drive problem- LG GSA-H10L
By pinetop in forum ComputerReplies: 9Last Post: 17th Apr 2008, 02:39 -
LG GSA-H22N misidentifies RW media
By Overwind in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Aug 2007, 14:54
