I'm using IsoBuster 1.5 and Tmpgenc DVD Author 1.5.15.49 and Win2K to try to put some VCD .DAT files on DVD. It seems that the files have to be good quality or Tmpgenc won't read or convert all of the file. Any blocking, etc. seems to trigger this, even tho the file is readable by the OS. There are no error messages when this happens; the file is only partially converted in the VIDEO_TS directory. The only way I can tell there's a problem is to check the .VOB file sizes to see if they look right or play the VOB file. Any advice?
Try cutting out the bad frames with virtualdub and frameserve to tmpgenc.
Thanks. I took a look at Virtualdub.
However, deleting each bad frame individually cancels the convenience I was hoping to have by consolidating my VCD's.
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 15:21 -
partial subtitles
By shredcaster in forum SubtitleReplies: 1Last Post: 2nd Jul 2009, 09:41 -
Partial Conversion of avi to DVD
By macsnooder in forum ffmpegX general discussionReplies: 2Last Post: 7th Feb 2008, 02:54 -
partial encode
By wkmanley in forum ffmpegX general discussionReplies: 1Last Post: 9th Oct 2007, 15:43 -
Playing partial mp4 files
By silverwolf0 in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2007, 10:43
