  1. Hi just purchased this yesterday any fellow owners out there with feedback?
    couldnt find a proper review on the web so i just purchased it anyway
    btw its my first home dvd recorder
    im quite computer literate and it does seem a little bit tricky to use
    so far i have recorder vhs to dvdr and a couple of episodes off sky digital
    it has been great with some 4 speed mirror dvdrs i had but i cant get datasafe 2 speed dvdrw to format any idea?
    exscuse the punctuation im not very good at english
  2. I was not able to locate manual of this unit. Do you know where to find it or would you scan it and post it on the web ?
    Where (country) did you bought it ?
  3. i bought mine in the uk from comet
    not really practical to scan the manual its loads of pages
  4. OK.... Maybe you can fill this up then
    DVD Recorder List in Excel format
