Ive read the guides but im a total nice but dim newbie.
I wanna back up a dvd.
The software i have is:
nero 6
alcohol 120%
clone dvd
i believe the dvd is about 7gb, i know it wont fit on a dvdr.
im not bothered about menu's etc at the present (i'll learn that later)
can anyone help?
thanks in advance
Results 1 to 12 of 12
I would suggest getting DVD Shrink it's free, it will rip and transcode to the correct size without much of a brain needed on your part. Just follow the guides under the link above. Then you can use Nero 6 to burn.
Follow Whompus' DVD9 shrink guide at http://www.polarhome.com/~afonic/shrinksplit.htm
This will make 2 DVDs with no compression used and therefore no quality loss.
Alternatively, you may also choose to deselect certain audio options, subtitles, menus, etc within DVDShrink in order to get it on one DVD with less required compression. There are many guides here to accomplish that but the program is self-explanatory in that regard. -
You say "Only the Movie" and then you said "The Whole DVD".
DVDShrink (which is free) can do either one. Assuming you can read english , follow the guides and your done. It's pretty intuitive, but it can do things most people hadn't thought of.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for that, do you know where i download them too?Originally Posted by MOVIEGEEK
In the post above, follow the link. Then click the download link in the new window. It will take you to where you can download the drivers.
when i click the download it asks me where i want to save the download...does anyone know?
Ok, you are a NOOB, huh. save them to a place you now how to find on your hard drive. then double click them to install.
I liked that. You also need to learn how to use your internet explorer!!.without much of a brain needed on your part
Idiot's Guide to Encoding
By sharpfocus in forum Newbie / General discussionsReplies: 4Last Post: 11th Sep 2011, 19:59 -
I need an idiot's guide to converting PCM to AAC or Vorbis!!!
By Nagashi in forum AudioReplies: 6Last Post: 4th Jul 2010, 17:07 -
An idiot-proof guide to converting DVD's to AVI/MKV/Whatever..
By krishock in forum DVD RippingReplies: 4Last Post: 12th Apr 2009, 13:49 -
VLC Media Player Needed: A Guide for the Compleate Idiot
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2008, 08:19 -
Mozilla is becoming *VERY* idiot-friendly :-(
By Midzuki in forum Off topicReplies: 10Last Post: 25th May 2008, 16:12
