I need to purchase an authoring application to add chapter points into a clip edited on Screenblast MS3.0.
I am told that TMPGenc Author is not only a good tool for this but can also be used to burn the DVD.
I am also told that Ulead Movie Factory is a good solution.
Is there any consensus on either?
Thanks,
Allen
For a newbie I would probably go with Movie Factory 2 over TMPGEnc DVD Author. I think right now MF2 is a better all around solution with a wizard type interface.
Hope this helps -
I vote Movie Factory as well. I found it much easier to use than the other.
I think the primary advantage of TMPGEnc DVD Author is the menu flexibilty. Basically you have more control over where things end up. But more often than not Moviefactory's templates do a great job of getting me there without allowing me to move buttons. Additionally Moviefactory 2 gives you other abilities that TMPGEnc does not, such as slideshows, direct burn and others.
Good luck
subtitles between applications?
By butterflies in forum SubtitleReplies: 0Last Post: 2nd Dec 2009, 11:53 -
fastest PC to run 32bit applications
By SingSing in forum ComputerReplies: 2Last Post: 19th Dec 2008, 09:58 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 20:45 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 13:08 -
newbie authoring
By ydobpbkwds in forum Newbie / General discussionsReplies: 6Last Post: 24th Dec 2007, 04:13
