Results 1 to 10 of 10
  1. I've followed the standard conversions guide on how to convert from PAL DVD to NTSC DVD. Everything works well until I try to encode it using TMPGE. Where the video window is, it says this: Unrecognized exception "C:\goodday.avs"; line 3" I've checked my AVS file and it appears to be correct:
    LoadPlugin("MPEG2DEC.dll")
    LoadPlugin("SmoothDeinterlacer.dll")
    MPEG2Source("C:\goodday.d2v")
    SmoothDeinterlace(doublerate=true)
    LanczosResize(720,480)
    ConvertFPS(59.94)
    SeperateFields()
    SelectEvery(4,1,2)
    Weave()
    ConvertToRGB()
    Also, my TMPGE says that it cant play back any MPEG-2 files. Please help!
    Apr 2002
    The State of Frustration
    TMPGEnc, you did by the registration, right?
    Hello.
  3. Yes, I bought the registration.
    Apr 2002
    And direct Show priority. Set correctly?
    Hello.
    Mar 2003
    Uranus
    If that's in the video window , then Avisynth said it, not tmpgenc
    try it with the minimum
    and open it with virtual dub if that breaks...
    You need probably to relaod avisynth and/or the mpeg2dec.dll
    there is another thread where someone fixed their problem by getting
    mpe2dec2.dll instead
  6. By loading the mpeg2dec.dll, all I have to do is put it in the Windows/system directory, correct?
    canada
    Windows/system32 if you are running win2k/winxp pro
    Mar 2003
    Uranus
    I put em in "plugins" under avisynth.
    There is a registry entry that specifies where they are
    so you don't have to explicitly load them
  9. Guest
    I run XP Pro.
    pasting BOTH DLL's at system32 DIDN'T work for me, I pasted them into system folder and it worked,
    Andre
  10. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Hello supersuit99
    I think you should read this THREAD:
    https://www.videohelp.com/forum/viewtopic.php?t=186685
    I believe reading this THREAD should help you to solve your problems.
    - John "FulciLives" Coleman
