Hi!
I would like to make a video CD (not a real VCD) just to be played on a Windows PC system, so I w'ont have to convert any of my video file (Avi, MOV, MPG, etc.)... it's more simple for me. Is there any program for building a DVD menu-like or an simple interface ? I've heard about "Quick menu builder" but it is not very easy...
Is there a way to put many video file on a CD, with a video player and all codec, so that the movies can lauch immediatly on any PC ??? (I don't need it to play on a standalone DVD-VCD player, just for PC)
May be I am asking too much ?
Thank you for any advice...
Luke![]()
I would say soOriginally Posted by luboshi
There may be one click type software available to do this for you, but I'm not aware of it.
The menu system could be made in (d)html, and made to autorun, or you could use Flash etc..
Including a player, and all codecs required - and especially making the disc check to see what codecs are already present on the system, and installing the ones that are not yet there... not a simple task.
I'd say this sounds like much more work than doing the appropriate conversion(s), and making a (S)VCD etc... or at least converting all the files to a common format (e.g. MPEG-1) which would make the process more simple.
There may be software out there to do all this for you - as I say - but I'm not aware of it.
cheers,
mcdruid. -
eMovix (just tried it the other day) is a pretty cool package, that together with a Windows GUI can create 100% self contained CDs with player and audio/video content. Target platform can be anything as long as it's a PC - it doesn't even have to have an OS installed, as the eMovix CD comes with a small footprint Linux installation "on board". Extremely cool stuff.
/Mats
Stretch video after convertion and burning
By Tonyphotoplus in forum Video ConversionReplies: 10Last Post: 10th Jun 2010, 05:08 -
64-bit Video Convertion Program
By Trickynick in forum Video ConversionReplies: 15Last Post: 25th Feb 2010, 18:57 -
Convertion problems
By M_2008 in forum ffmpegX general discussionReplies: 2Last Post: 4th Jul 2008, 16:49 -
mp4 convertion
By ht0160 in forum Video ConversionReplies: 2Last Post: 15th Feb 2008, 02:09 -
Video convertion
By kireetkvn in forum Newbie / General discussionsReplies: 3Last Post: 10th Sep 2007, 01:50
