HI guyz![]()
I have this divx file which was converted into mpeg with our good all way, by striping off the wave file off the movie using Vdub. but this divx file has the audio sync problem in the original file.
what should be done. plze help
Results 1 to 15 of 15
Is there an easy way to determine the amount of out-of-sync, or do you just have to do trial and error runs?
A stopwatch can help. There is a shareware one available.
Hello. -
Hi
yeh stopwatch help.
wel the video is 12 sec aheadto the audio.
plze help.
and how do u set and offset while encoding inTMPGEnc -
If it does not cause too much trouble, load the original video into Gold Wave. Select Edit-->Silence. Add 12 seconds. Save the file as a wave file. Go to TMPGEnc, load the original video as input video, and the new wave file as input audio. Name the new file. Select Start. The new video should be in synch.
If the video is extremely long, try doing this with a five minute sample first.Hello. -
You can set an audio delay in Virtualdub and it's easy to test as well. Load your avi in Vdub, go to audio>interleaving and then you can enter a number under delay audio track. The digits are milliseconds so 1,000 = 1 sec., positive #'s move the sound later and negative #'s start it sooner. When you have entered a number then you can test the delay by playing the video in Vdub by hitting the > button. You can drag the indicator to different parts of the video to test it in several places. Stop the video and make any adjustments until you get it right. File>save wav when you're done or you can frameserve the audio and video together.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by nirbhayn
Whenever I have had to use this feature I have just encoded a minute of the footage and used trial and error to get the number of milliseconds just right so that the audio syncs. If you put a value in and it gets worse use a negative value. -
ZippyP's way is probrably much easier and quicker.
Set the audio to full processing mode and it should keep the delay when saving wav or frameserving..Originally Posted by rdfarr"Art is making something out of nothing and selling it." - Frank Zappa
hi again guyz
i tried zippy's technique. but when i set this value (1000x12 = 1200) nothing relly happens. does it have to be et to ful process in the audio tab. -
Read the post directly above yours.
hey guyz me bak again with a problem.
the first part was fixed successfuly but the second one has bad frames but i think masked, because i checked and it said no bad frames found. i tried that trick that zippy tought me but when masked frames starts playing in the video it goes out of sync again.
what can i do in this case. -
If you know where it goes out of sync then you need to edit out the bad frames from your original file. Use virtualdub again, there's a guide on how to edit with it in the Edit section.
most common used converters
By alijutt in forum Video ConversionReplies: 0Last Post: 22nd Dec 2011, 20:35 -
What's the most common video format?
By chrisj in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2011, 18:03 -
Common questions and answers.
By Faustus in forum DVD RippingReplies: 31Last Post: 27th Feb 2008, 06:21 -
Is This A Common Problem? DVDr to AVI
By innovyse in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 05:09 -
Is Clear QAM common?
By Mormegil in forum DVB / IPTVReplies: 11Last Post: 26th Oct 2007, 14:13
