I've created some DVD compliant MPEG-2 files using Ulead VideoStudio 6. I can burn a DVD with these files using Ulead MovieFactory 2, but not with Sonic MyDVD. The Sonic software transcodes the audio and churns away for about three hours, then comes up with the message, "File is not a valid MPEG." Here are the specs of my files:
NTSC drop frame (29.97 fps)
Field order A
MPEG files
24 Bits, 720 x 480, 29.97 fps
(DVD-NTSC)
Video data rate: Variable (Max. 6000 kbps)
Audio data rate: 224 kbps
MPEG audio layer 2, 48 KHz, Joint stereo
Why would this not be a valid MPEG? What does MyDVD consider valid? I wouldn't bother with the Sonic product, were it not for the fact that it does motion menus, which the Ulead software won't do.
Michael
Not sure about the video being rejected, though I know some previous version of MyDvd were fussy about the GOP structure. Audio though I understand why it transcodes. MyDvd only supports LPCM audio.
Ulead is backwards , Field B is top field first
maybe that's it but I doubt it takes 3 hrs to find out.
Blu-ray disk authoring: BD player rejects them
By swraman in forum Authoring (Blu-ray)Replies: 16Last Post: 26th Sep 2009, 08:39 -
Combining Sony mpeg2 files with m2ts files
By hsid in forum EditingReplies: 8Last Post: 2nd Mar 2008, 21:51 -
trying to put VCD files on a DVD with MyDVD Express
By curt1sw in forum Authoring (DVD)Replies: 7Last Post: 15th Nov 2007, 15:42 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 20:48 -
Trouble when saving MPEG2 Ulead VideoStudio 10
By faramith in forum Video ConversionReplies: 3Last Post: 13th May 2007, 10:17
