Hello all,
I have a dv file captured with my canon zr-10 camcorder (interlaced i think) and i want to convert it to dvd format so i can create a dvd later. I am using tmpgenc, but i am not sure if i need to deinterlace the source or not. When i play the file encoded in tmpgenc without deinterlace on bsplayer, the result is not very good. But i will only play the dvd that i will create, on stand alone dvd players and windvd. So do i need to deinterlace the source or not?? If i really need which of the tmpgencīs filters are the bests to dv source?? Tanks for the help.
Cyro
If the intent is to play on a TV or other Interlaced scanning device, then you do not de-interlace.
If the intent is to playback on a computer or other progressive scan device, then you must de-interlace in order to avoid "comb effect" distortion.
Rule of thumb ...
Capture (Interlaced or Non-interlaced) based on the source .
Encode (Interlaced or Non-interlaced) based on the intended viewing device.
** If you will be playing it on both interlaced and non-interlaced devices (i.e. TV and computer), I would recommend leaving it interlaced and use a computer software DVD player that automatically de-interlaces. I know PowerDVD does, but I don't know about WinDVD.
Best Deinterlace settings for this source?
By alcOre in forum Newbie / General discussionsReplies: 32Last Post: 22nd Oct 2015, 15:24 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
Best Way to Convert and Deinterlace VRO
By Spiralagnus in forum Video ConversionReplies: 8Last Post: 4th Dec 2010, 18:29 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11 -
4:3 source AVI to 16:9 mpeg2
By JoeMuskie in forum Authoring (DVD)Replies: 10Last Post: 10th Sep 2007, 08:52
