I'm hoping that kabanero or somebody else who owns one can answer, so here goes:
I haven't been able to find a copy of the LiteOn manual, but other posts in these forums say that the Gateway 230 is just a rebadged 5001. In the Gateway's manual, it only mentions being able to pause while recording when the input is set to the tv tuner.
Is this an actual limitation in this unit, or can you pause while recording with an RCA, S-Video or FireWire input source as well?
If there's no pause function, I'll have to stick with the LONG way for LaserDisc backups (record to DV, then convert on the computer. Time-consuming, but I can get everything into one title).
Thanks in advance!
Results 1 to 9 of 9
You can pause and un-pause any recording from any input. I have done this to edit commercials from TV programs originally recorded on VHS. The only thing you can't do is change the type of input while in the record mode even when paused.
Cool! the best part is that I don't have to worry about the local CompUSA selling out before Christmas. Their web site said they had it in stock at my store, but I couldn't find it. When I asked, the frustrated sales guy told me that they had a corporate audit, and even though the product appears in their newspaper ads, it's not in the "official layout" that the auditor uses for the inspection. They had to take them off the floor. He showed me a back room with 20 of them sitting on a shelf.Originally Posted by RowMan
Luck me I got my LITEON LVW-5001 from Compusa just one day right after thanks giving Sunday, so PPl thinking they already went to Compusa picked up goodies on that Sunday , but the LITEON start on sale on the next day Monday.
Yes you can pause while recording, and you can also go to setup to adjust recording mode , so your next time recording will use the new setting.
Here is what inside my Liteon lvw-5001
http://fire.prohosting.com/aiblue/liteon/ -
Can anybody help with these questions ?
- Does it play MiniDVD (DVD format on CD) and does it play mp3 on DVD ?
- Does it also output through FireWire ?
- Can you manualy create or delete chapter mark ?
- How does it make chapter marks from DV IN ? (some creates whenever camcorder was stoped,paused)
- Can you change index picture in menu ?
- Does it record Closed Caption ?
- Can you assign 4 letter code to TV station ?
- How many Timer recording can I enter ?
- Can you setup "One Touch Recording" that will set in 30min increments how long it will record ?
- How does it record from 16:9 source ? 16:9 or 4:3 with black bars ?
- Does this recoder convert between PAL and NTSC ?
Thanks.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Let me try...Originally Posted by donpedro
Can not play MiniDVD smoothly. Not support. Play MP3/JPEG (and all together) in ISO/UDF format, no matter what kind of media.- Does it play MiniDVD (DVD format on CD) and does it play mp3 on DVD ?
No. Only input.- Does it also output through FireWire ?
No.- Can you manualy create or delete chapter mark ?
Chapter marks are caculated in "minutes". No matter what source is used. Sorry. Don't know much about the details.- How does it make chapter marks from DV IN ? (some creates whenever camcorder was stoped,paused)
No.- Can you change index picture in menu ?
CC stream can be recorded but can not get it to be played.- Does it record Closed Caption ?
Possibly no.- Can you assign 4 letter code to TV station ?
Five.- How many Timer recording can I enter ?
No. After instant record is activated by press [record], default record quality will be used and user has to stop recording by hand.- Can you setup "One Touch Recording" that will set in 30min increments how long it will record ?
4:3 with black bars (I think).- How does it record from 16:9 source ? 16:9 or 4:3 with black bars ?
Convert? Don't quite understand what you mean. But the system can switch between PAL and NTSC.- Does this recoder convert between PAL and NTSC ?
Hope this helps. -
I hate dvdplusrw.org down again!!
Hi skysknight , any idea new firmware for lvw-5001 will be out?? any new enhancement ^_^
Any idea when we can buy lvw-5020 in US??
I own PANASONIC dvd -ram recorder with HDD, they have a very nice feature that I like , the FR recording mode
meaning if I already recorded 10 hours movie in HardDisk, I can not fit into a single DVD without using FR, the FR recording mode will pick the best recording format to fit 10 hours movies already recorded into HD into 4.7 GB media ^_^. -
Time to switch to best forum everOriginally Posted by smartblue
Based on manual it is 6h maximum so forget about 10hOriginally Posted by smartblue
Did you test it ?Originally Posted by skyknight
Does it take "first frame" from program or some fram that is later in the program ?Originally Posted by skyknight
So it records it and it can be played on another DVD Player ?Originally Posted by skyknight
Can you play PAL DVD on NTSC TV or NTSC DVD on PAL TV ?Originally Posted by skyknightPinnacle Studio 8 and DV home video editing (ver.9 already home)
Liteon LVW-5101
By vmelkon in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Feb 2011, 16:28 -
Repairing a Liteon LVW 5001
By Toxie in forum DVD & Blu-ray RecordersReplies: 15Last Post: 19th Nov 2008, 11:49 -
Gateway AR-230 flashed to LVW-5001 , DDW-451s to LDW-451s, SUCCESS!
By FiremanPete in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th Jun 2008, 22:15 -
Liteon 5001 and HQ mode problems
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 1st Oct 2007, 00:49 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 08:50
