I have a Movie File MPEG and I need to crop it and convert it to widescreen to later burner as a VCD.
Can u tell me what prog can i use or gimme a link for the crop and widescreen thing.
I"m confused with the articles been trying for a month now!
thx in advance!![]()
Try TMPGenc.
Load the video file and go to click on SETTINGS. Then select ADVANCED tab and file and double click on CLIP FRAME. This will allow you to "crop" the video.
If you are not familiar w/ TMPGenc, there are many guides here that will give you a leg-up on getting the most out of this GREAT program. -
THX Ripper2860
Can i use this same prog to convert it ti wide screen?
...or i have to use some other prog? thx again! -
Not really sure as I have never tried to convert a non-widescreen movie to wide-screen. You may try looking at the options in TMPGenc (SETTINGS/ADVANCED/VIDEO ARRANGE METHOD) and try different settings with a short clip (SETTINGS/ADVANCED/SOURCE RANGE) to see if any of the options will achieve your goal. This would be after you've made the adjustments in CLIP FRAME.
Some of the guides may be helpful in understanding the end-result of VIDEO ARRANGE METHOD selections.
Good Luck !!
MKV Fastforward Hand Break
By leftspeaker2000 in forum Newbie / General discussionsReplies: 4Last Post: 7th Apr 2011, 10:28 -
What hand are you?
By johns0 in forum PollsReplies: 9Last Post: 26th Mar 2010, 03:38 -
The Hand of God
By deadrats in forum Off topicReplies: 2Last Post: 26th Apr 2009, 10:32 -
i need a hand with my vhs uploading
By alique in forum Newbie / General discussionsReplies: 8Last Post: 27th Jul 2008, 16:32 -
Trouble With DVD Author. Please give me a hand.
By hellfire45 in forum Video ConversionReplies: 1Last Post: 19th Nov 2007, 01:31
