If I encode my svcd using the default svcd values for NTSC ie. resolution, aspect ratio, digital pixel ratio. Then will it fit on the full screen of a North American NTSC television screen when I play it in my DVD player.
1)Using CD-r's
2) Canopus Encoder (should not matter?)
3) File output is *.mp2
Thanks yall,
Dino![]()
I think that should be maybe!Originally Posted by gmatov
It actually depends on the aspect ration of the source.
e.g, if your source is avi with res 640 * 480, the it will fill the screen. BUT if your source is 640 * 320 and you configure your encoder to maintain that apsect ratio (to ensure it looks correct on the Tv) then it will display letterboxed on the TV.
There is a good guide/thread in the user guides forum on understanding aspect ratios, take a look.
HandShake:Type mismatch: client sent 6, server answered 9 with with RMPDump
By Joélle in forum Newbie / General discussionsReplies: 0Last Post: 17th Feb 2012, 17:16 -
I know you guys have answered this a lot, but on Burners
By tcory in forum Blu-ray RippingReplies: 3Last Post: 23rd Jan 2011, 21:39 -
How do i get my questions answered on these forums
By dumwaldo in forum Newbie / General discussionsReplies: 93Last Post: 26th Mar 2008, 19:44 -
spumux button order is off [answered]
By raschko in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2007, 10:08 -
Adding subtitles (srry if youve answered it many times)
By hellfire662 in forum SubtitleReplies: 4Last Post: 16th Sep 2007, 13:01
