When I burn a movie and play it on my dvd player, every time theres a bright flash or bright white the sound cuts out.
Why does it do this and how do I fix it?
Its really bad on cartoons.
Results 1 to 11 of 11
Have you checked for bad frames in the source ?
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
It has nothing to do with the frames.
It plays on the computer from file just fine. When I burn it and play in my dvd player the sound cuts out when theres a flash or bright light.
How do fix it? -
Before I am able to say if I can help you or not you're gonna have to provide more info. The only thing I know so far is that some kind of disc you have wont play in your dvd player properly.Originally Posted by MEANGUNS
I converted a avi file to a svcd as I normally do. But all movies I convert when I play them on my dvd player, every time theres a explosion or a flash the sound cuts out for a couple of seconds.
So now a have a GI Joe movie cartoon, that is all shooting and flashes.
The sound cuts out so much because of all the shooting and exlposions.
Bright light makes the audio cut out too.
My dvd player is a norcent from wally mart, wich as never given me any problems.
Please help.
Also when I play the svcd or original avi on my computer the sound does nto cut out. -
Have you tried a SVCD from any of your friends?
Do you only have this problem when you play SVCD or do you have the same problem when you play VCD's and selfrecorded DVD's? -
This happens on every SVCD ? What about VCD ? By the sounds of it your DVD player doesn't like SVCD.Originally Posted by MEANGUNS
it happens with all vcd s mpegs and svcd...
Ill try it on a another dvd player and see if that makes a difference, if it doesn't what else can I do? -
Your source is set to look good only on the 0-255 palette, not a tv 16-235 palette, and you are getting all 0-15 colors washed to pure white. It's an encode/user error.
You guys where right!
It was the dvd player. GoD DAMN IT!
I tried the same svcd on a newer and cheaper Norcent player and it wored perfectly.
Well atleast I know what the problem is.
Thanks for the help. -
@MEANGUNS
Just post the type of your Norcent DVD player, perhaps owners of the same player know some tricks.
Audio Cuts off on mkv convert
By koberulz in forum Newbie / General discussionsReplies: 0Last Post: 8th Jan 2012, 15:27 -
Audio cuts in and out
By the0ryyy in forum EditingReplies: 1Last Post: 15th Feb 2011, 17:41 -
audio cuts out for SD content
By scarecroe in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th May 2010, 15:19 -
audio cuts out in staxrip conversion
By RH7162 in forum Video ConversionReplies: 0Last Post: 5th May 2009, 20:40 -
Audio Cuts out With GotSent on 5.1
By Calippo in forum Video ConversionReplies: 6Last Post: 4th Feb 2008, 20:29
