  1. I have a gateway solo 2100 laptop that I bought used a few years ago. I dont use it so I'm going to put it on ebay.
    I need to fing out what size processor it has. Where can I go on the pc to find that ??
    I found the RAM ...and the HardDrive size...just need the processor speed.
    thanks
  2. Banned
    Nov 2002
    Pgh Area
    How about gateway.com? They'll tell you stuff you didn't want to know.
    Other than that, go to www.sisoft.com , dl Sandra, and run it. It will tell you even more than Gateway will.
    George
  3. Right click on My Computer, then Properties.
    In the General tab it will have you computer information like the CPU speed.
  4. Banned
    Nov 2002
    Pgh Area
    I can't believe I forgot that. I remembered it would tell you the OS and RAM, but didn't remember the Proc speed showed, too.
