Hey guys, sorry my first post is a tech question but I am hoping someone can help me out. I have just bought the recordable dvd player in the title of the topic and am overall very pleased with it. However, I cannot seem to turn on the digital output on it. It wants to output to the television via the SCART rather than via the optical. I have looked everywhere for a sound settings menu but cannot find one.
If anyone has any ideas I would be most grateful.
TIA
As this uses the Cirrus Logic chipset (as does the Sampo DV-R1 and DVE-R3) hopefully I can help.
On your menu called AUDIO SETUP there should be two options - AUDIO OUTPUT and one called SPDIF.
Go into the one called SPDIF (stands for Sony-Phillips Digital InterFace, by the way - ie coaxial/optical digital audio output) and select either BITSTREAM or DIGITAL - this should override the existing audio method you're using
Webmaster of Area 450, the independent site for owners of Sampo and Maxent DVD products the world over -
This is the problem, if I go into SETUP all I have on offer is Language, Video Setup, System Info, Disc Media, Recording and Schedule. Nowhere throught the menu system is audio mentioned.
I am totally confused, it has RCA digital out and optical digital out and no way of telling it to do either.
Any further ideas would be much appreciated.
P.S. It does have a display on the front. Someone here thought it perhaps did not but it lights up when turned on. -
Hmm, that's bizarre, isn't it ?
I'm wondering whether it's one of these products that simultaneously sends out a digital and analogue audio signal from both optical and analogue cockets, in which case could the problem be at the amplifier end ? What are you plumbing her in to ?Webmaster of Area 450, the independent site for owners of Sampo and Maxent DVD products the world over -
Into a Kenwood KRF-V5050D dolby digital amp. Everything else I have plugged into it autodetects no problem. That includes an XBox and my nForce2 mainboard. I am sure its not the amp end.
Its got me totally puzzled and as usual Dixons are as much use as a fart in a thunderstorm. I rang them and was given the number for someone who handles Grundig affairs in UK and also the Mastercare number. Mastercare promptly said we can charge you £25 to come out and install it but we don't offer technical support, Dixons should have told you that.....they didn't surprise surprise.
So I am gonna go into store when I can and tell them to show me on their demonstration model and if they can't do it then I shall be playing merry hell 'cos the staff should damn well know their stuff if there is no tech support for backup and they own the Grundig brand name.
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
Simple Guide : How to convert DD5.1 AC-3 448 / 640 to stereo.
By Bonie81 in forum User guidesReplies: 3Last Post: 13th Jul 2011, 09:55 -
Grundig GDP2750
By Socio in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st May 2008, 13:11 -
Viewing and Burning 1080i DD5.1-CtrlHD.ts.par2 files
By Sharkman in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2008, 14:07 -
Grundig gdp 1750 region hack
By matje06 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Jan 2008, 16:02
