I been using this program for months now, great work Chissyboy,
Now I am having a problem, I riped the bin files then made the menu, everything looks good check the box for ac3 audio using ffmepeg encoder, And newest version 1.5 bulid 2003.0
And here is the log file!
Starting SVCD2DVD: v1.5.2003.0
Begin time: 3:49:30 AM
******** Ripping BIN images to get mpegs (VCDGear)
(Total size: 1010MB, Duration: 00:00:00, Rate(MB/Min): 138,514.29)
Analysing File: C:\Comp DVD's\Intolerbale\lmt_ica.mpg
Analysing File: C:\Comp DVD's\Intolerbale\lmt_icb.mpg
-->Processing 2 mpeg files.
############### New MPEG File ###############
Type: VCD
Horizontal Res: 352
Standard: NTSC
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 0MB, Duration: 00:00:00, Rate(MB/Min): 0.00)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 0MB, Duration: 00:00:01, Rate(MB/Min): 0.00)
******** Multipexing elementry streams
Analysing File: C:\Comp DVD's\Intolerbale\lmt_ica_DVD.mpg
Type: VCD
Horizontal Res: 352
Standard: NTSC
(Total size: 0MB, Duration: 00:00:00, Rate(MB/Min): NaN)
Analysing File: C:\Comp DVD's\Intolerbale\lmt_icb_DVD.mpg
******** Creating DVD Folders...
Creating VTS #1
============ Complete ============
============ Duration: 00:00:03
You can see it does everything and 3 seconds, whats wrong???![]()
Are you starting with a folder of BINS or MPEGS? If bins is the FIX option on in the options window?
