Hi
i Have a Pickaone Dual Dvd -/+ rewriter
the problem is when i go to burn anything onto dvd nero will not let me select the lower speed
my burner has 2 speeds 2.4x and 4x but it only lets me select the higher speed and some things i have done have come out abit jerky so i was wanting to burn at the slower rate
any ideas
cheers
steve
P.s when i do a cd i have no probs i can select any speed,is there a better program i can use any suggestions
Do you have the latest version of Nero installed. If not I would go download and upgrade it and that most likely will work. Some drives are not recognized or have minimal functionality but in later version of Nero it may be fixed.
Also try flashing you drive's firmware to the latest version. This can solve the problem as well. Go http://forum.rpc1.org/dl_all.php to find and download the newest firmware. -
When you go to burn there is a button you can check to have nero test for the max speed to use. It will run some tests and then set the speed at one that will work.
looking for s/w that can recreate an MP4 file at slower playback speed
By ginahoy in forum EditingReplies: 9Last Post: 11th May 2021, 07:37 -
Video encoding speed slower than previously
By genak in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 18:23 -
How to Burn at 16 speed or better with 4 burners
By burn master in forum User guidesReplies: 9Last Post: 30th Mar 2010, 20:49 -
burn speed for videos
By gameroftheuk in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2008, 12:51 -
What Speed should I burn DVDs?
By Sudden Impact in forum Newbie / General discussionsReplies: 6Last Post: 9th May 2007, 07:11
