  1. installed xp pro,sp1 & updates, installed Vir. Dub 1.5 and huffyuv,
    took me ages to get pic. on the cap. screen and now on a seperate BLACK window from V.Dub full of follwing and like ;
    compress Query:input =YUY2, 16 BiTES. OUTPUT=( null )
    compress Query:input =0,16 bits, output=(null)
    App name is Virt. Dub.exe; flags= 0
    compress Query:input =0,24 bits, output = (null )
    any ideas what is causing this and the remedy for this prob.????
    best regards to you all even if you may not able to help.
    Murat Turel
  2. Member Leoslocks's Avatar
    May 2003
    Hard to tell if it is a Hardware conflict or a Software confilct.
    Virtual Dub has 1.5.10 out I believe.
    Go over your Display Settings. Perhaps check the devices connected to the sound.??
