  1. AnyDVD 3.2.1.1 is Out
    What is Anydvd
    AnyDVD is a driver, which descrambles DVD-Movies automatically in the background. This DVD appears unprotected and region code free for all applications and the Windows operating system as well. With AnyDVD's help copy tools like CloneDVD, Pinnacle Instant Copy, InterVideo DVD-Copy, etc. are able to copy CSS protected Movies. With the help of AnyDVD you can watch movies with non matching region codes with every DVD Player Software you like
    For me this software is great because you can back up all your DVD'S and put the original up safe some where away from the kids. And you can still back up all your DVDs if they are copy protected or not. And also you can fit like a 7GB movie onto a 4.5GB disk and the quality is just as good as the original. With anydvd and clone DVD together you can make a perfect copy of your DVD
    if you want more info on anydvd go to
    www.slysoft.com
    if you want more info on Clone dvd go to
    http://www.elby.ch/en/products/clone_dvd
  2. That is sooo true man!!! I'm doin' this for quite a long time and it seems to be the perfect combination...clonedvd & anydvd in the background is superb!!! And very easy to use too...
    Calvin
