I have tried using Besweet but I keep messing it up.
Is there another choice?
"Today is only yesterdays tomorrow"
Have you tried the one that Baldrick created aka ffmpeg ??
App: ffmpegguiI made a very simple wav,mp2,mp3,avi to ac3 gui for it.
Here's the link he started:
* ffmpeg windows build of version 0.4.8?
Otherwise, what issues are you experiencing, so that others can help you
here ?
Hope that helps.
-vhelp -
Thanks Baldrick..
To cut along story short,I have been trying (without much success I might add) to convert a PAL Xvid to a NTSC Xvid and perhaps then to DVD.
Its strange because even although I end up with identical lengths(after demux)the rejoined ,converted pieces still end up way out of sync.
I do realize from reading several tutorials that the framerate conversion is far from a perfect science and more often than not works out with sync issues."Today is only yesterdays tomorrow" -
@ wee haggis,
Have you tried first converting your Xvid 's wav to AC3 first,.. and then see
if it's still giving your the issues (your sync) yet ??
Maybe that will work first. I don't know, cause I'm not an audio guru, but
I'm learning :P
-vhelp -
Yes...I used Baldrick's GUI and it ended up about 5 secs out of sync with demuxed AVI.
I tried another method where I opened the PAL avi in Vdub > changed the framerate to 24 > then saved Video only > I then saved the audio as a wav > then opened it in the WAV2AC3 GUI > I then opened the WAV in Goldwave and did a Time Warp > muxed them back together > It was close but still about 2 secs out at the beginning and 1 sec out at the end (strange as it may seem)."Today is only yesterdays tomorrow"
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 15:12 -
how can we convert ac3 to wav?
By sumeshkri in forum AudioReplies: 6Last Post: 4th Sep 2008, 03:29 -
Convert 2.05gb wav to AC3
By colt4523 in forum AudioReplies: 7Last Post: 15th Nov 2007, 07:28
