hi![]()
I'm having a problem burning a film in nero, I've burned a couple of films in this format before and had no trouble. After burning the movie, put in dvd player and it loads just to find a screen that says converted by nero!
Has anyone any idea's
many thanks
kb![]()
Is nero re-encoding the file. You need to turn off standard compliance so that nero won't re-encode a non compliant KVCD file.
Also, turn off Neros menues.
/Mats
(And as always: Use VCDEasy to author, Nero to burn.) -
hi
read both posts, how do I turn of the non compliance and the re-encode on nero, also the menu's, it's nero 6 ultra.
many thanks
kb
Untick that box. This is 5.5 dont know if 6 looks any different.
Untick this box to disable menu
I have that same problem too but your movie is still there and can be played. If your remote control has a button that allows you to select which track you wish to play, then you can bypass that unusable menu created by nero.
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08 -
trying to burn a KVCD using Nero SmartStart Essentials
By nudge in forum Newbie / General discussionsReplies: 5Last Post: 28th Jun 2007, 15:10 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 20:05 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 08:01
