Everytime i try to load my mpv or my mp2 file as soon as i click on the tab to load BBMpeg shuts down. Does anyone else have this problem or don't have this problem and if so how can i fix it? any help would be appreciated. thanks
come on people, if you even have an idea please let me know. this is the only bug i have found running winxp. If you have an alternative to bbmpeg please let me know. bbmpeg is the only muxxer that i know of where i don't get out of sync a/v.
I know one thing, double posting the same subject is the quickest way NOT to get any help on this...my BBmpeg works fine, since it not an app that does an install....I would try downloading from another source, and see if maybe XP just doesnt like that version of BBmpeg, or run the .exe in compatibility mode.
I previously posted a topic about this exact same problem. And yes it was answered, you should search the forum before posting. =)
To fix this 'bug', simply load bbMPEG, hit LOAD, press Escape, then continue your usual business. The files will load just fine from now on. -
Thanks for answering and sorry for the double post but i waited many hours to see if anyone would respond and know one did so i thought maybe i should post in a different forum. Again thanks you for answer.
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45 -
cloning winXP system disk problem
By deejay.2001 in forum ComputerReplies: 1Last Post: 15th Jun 2009, 15:54 -
Does WinXP fix a known Win2k problem?
By bevills1 in forum ComputerReplies: 6Last Post: 28th Feb 2009, 23:34 -
Auto play problem in WinXP SP2
By bevills1 in forum ComputerReplies: 4Last Post: 3rd Mar 2008, 11:09
