Here is my situation:
I captured 1:12 minutes of Svhs video to AVI using Virtual Dub @ 720 x 480. I end up with a 29.1 gig file, 712 x 467 with Audio @ 44.096Hz. (VT adjust +167 ms)
Next I use Virtual Dub to edit the file. I use a deinterlace filter to merge the scan line and crop the noise(5,3,8,5 pixels).
I also use a resize filter to force it to 740 x 480. I end up witha 47 gig file.
I Save WAV ... the file and have the audio in WAV format to work with. I have even used ffmpeg to creae an AC3 file of the audio.
What I am trying to do is get the audio syncronized. There is a short lag between the video action and the sound being played. From what tutorials I have read,
I need to Reencode the audio at 48khz
Or render the Video as VS(Video only) and then Mux the AC3 file ito it?
I lose about 15 frames during the capture. The origional tape has some flaws to it so I account the lost frames to spots on the tape. I have read so many tutorials I have confounded myself. I need to get a grip on the basic points to eliminate or fix this audio problem.
For every three steps forward, I slide back two steps.
Results 1 to 1 of 1
audio lag in .mov to .flv converted files
By french-petzouille in forum ffmpegX general discussionReplies: 5Last Post: 3rd Mar 2012, 12:05 -
tsMuxeR and Audio Lag
By imrealdumb in forum Video ConversionReplies: 3Last Post: 14th Jun 2011, 18:28 -
Audio lag after conversion to DVDmpeg2enc
By macgurl in forum ffmpegX general discussionReplies: 5Last Post: 8th Aug 2010, 02:42 -
DVD RIP, Audio and Video Skip/Lag
By Blue_3 in forum DVD RippingReplies: 4Last Post: 8th Apr 2008, 07:34 -
After using ConvertX, major audio lag
By bear2616 in forum AudioReplies: 4Last Post: 17th Oct 2007, 13:42
