Hello i have a problem here, i resently got a nec nd 1300a dvd -/+ recorder and have tried to burn backups of a couple of my ps2 games, i have tried almost every dvd burning software there is but with the same result. I first do an iso image of the game, then burn it onto a dvd-r and everything seems to working fine, but when i put the backup in the ps2 nothing hapens, it just won't read the backups. I have used princo dvd-r and a tdk dvd-rw and tried to burn at all speed from 1x-4x. My ps2 have a messiah chip inside and works fine with regular cd-rips. So now i wonder,,is it me that do something wrong here when i burn? or do anyone else have any good ideas of what it could be?
Results 1 to 9 of 9
give nero and alcohol 120% a try. if that doesnt work, i dont know what to tell ya.
Try using either Ritek DVD-R or Apple DVD-R anything that has a dark deep purple writting surface, I know that Some playstations that had mod-chips in them have a hard time reading cheap name brands like princo. Also I have A Magic 3.1 chip and for some reason it always has a hard time reading DVD-RW disk. Also Always burn your games at 1x people are having alot of problems with 2x-4x speed. I use Nero To copy my back-ups and they always work on my PS2.
use DVDDECRYPTER in ISO-mode. It works great with PS2 dvd-rom games. I have a PS2 with the MESSIAH chip (first version) and PRINCO dvd-r works fine for me. No problems at all. Try burning only at 1x speed. Also I must click twice the reset button (1 second between the clicks) before I can play a dvd-rom backup. Maybe you should try click twice the reset button on your PS2.
Hello again, i have now solved my problem with my ps2 backups. i downloaded the new adaptec aspi drivers and also downloaded new drivers for my motherboard (abit nf7s), then i tried to burn a backup using dvddecrypter and,,,damn,,it works
, i used my princo dvd-r and they burned with no problems at highest speed 4x. but i have one more question here regarding dvddecrytper, when i burned the backup i ´set the writning speed to 1x but when the burning started dvddecrypter automaticly changed to the highest speed,,how do i do if i want to burn at 1x?
anyway thanks for the tip about dvddecrypter but i didn't have to dubbleclick the reset button for it to start, just put the dvd in and restarted and the game started. i also have messiah version 1. -
Hope this thread doesn't get deleted. Maybe the offer to sell post only.
Question, (yes I am kinda hi-jacking this thread a bit, hope you don't mind) how come game consels need mod chips to read burnt disks?
Computers and DVD players don't need them. -
There already lots of topics on this but since I used to mod a ps2 forum here is what to do:
Use only dvd-r media
Get a mod chip. You cannot play without one! There is a fliptop case with disks $50 instead of a chip. I wont say where to get one but search the net, easy enough.
Ps2 Burning Problem
By waazzaa101 in forum ComputerReplies: 17Last Post: 21st Jun 2012, 20:47 -
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 16:48 -
Fred Claus DVD Backup problem
By HmNtr in forum DVD RippingReplies: 5Last Post: 1st Dec 2008, 02:23 -
Dvd backup problem
By RemainsHuman01 in forum Newbie / General discussionsReplies: 5Last Post: 20th Aug 2008, 03:01 -
DVD backup problem
By 557953 in forum Authoring (DVD)Replies: 5Last Post: 21st Aug 2007, 12:30
