I want to make a compilation DVD with a couple of clips I 've recorded from TV and and a couple I've converted from an enhanced CD. I always use TMPGENC DVD Author for my work and am using TMPGENC for the re-encoding. TMPGENC won't let me make a compilation from the re-encoded clips at 720 x 480 on the same DVD as a the clips that are 704 x 480. Is there any way that I can put all of this on one DVD? Thanks!
Just click on Add new track (to the left under the Tmpgenc DVD Author Source setup step) for each different video resolutions.
You can't mix video resolutions under one track/vts. -
IIRC, the DVD specs allow for different resolutions on one disk but they must be in seperate titlesets. Unfortunatley, the consumer lever DVD authoring packages generally only generate single titlesets.
You could try an authoring package that accepts non-compliant or mixed resolutions. DVD-Lab will probably accept them (with a warning) and allow you to author. As to wether this will play correctly on oyur DVD player, only way to find out is to try it. -
Originally Posted by Baldrick
Originally Posted by bugster
I have MF 1 and it won't let you import two differing resolutions. I had tried to use DVD Patcher but although I could patch and get MF 1 to accept the file, I couldn't "unpatch" after I'd authored them. Does anyone know of a simple way to "unpatch" certain titles in an authored VIDEO_TS folder?
I just finished making a DVD with 8 mpeg2s.
5 were 720 x 480 and 3 were 352 x 480 All were 4:3 DAR
MF2 just did it without complaint. I never even noticed until
I looked at the files and found 2 title sets.
maybe it doesn't like 704
Trying to edit various source clips, different resolutions in Sony vegas
By sevenofone in forum EditingReplies: 4Last Post: 30th Jan 2011, 16:29 -
How to put clips together in AVCHD/m2ts format?
By vpelton in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2011, 08:31 -
is there a DV editor that can import all clips and put them in order?
By Onceler2 in forum EditingReplies: 0Last Post: 15th Oct 2010, 21:38 -
Issues Authoring DVD with different resolutions
By Smack2k in forum Authoring (DVD)Replies: 3Last Post: 11th Nov 2009, 02:24 -
DVD screen capture resolutions???
By cabala420 in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2008, 11:28
