When I burned my .AVI movie in NERO VISION EXPRESS 2 to a DVD, the program transcoded my video and then burned it. It went fine and the audio and video sync was nice and the quality too. But the problem is that the movie "hacks", but very little. It hacks continuously and with the same spaces.
Do anyone know why?
What do you mean by "hacks"?
If you mean it has artifacts such as visible discolored blocks then it probably has something to do with the .avi codec. Try updating your codec for whatever video format your .avi is in and maybe turn off some of the postprocessing features. -
I mean that the movie is a little bit jagged, but very little. But enough to be disturbing..
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Easiest way to "black out" a small section of video in an AVI file?
By johnny905 in forum EditingReplies: 7Last Post: 24th Mar 2010, 07:14 -
HD camera for recording small LCD screens + "normal" use?
By sincostan45 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Mar 2010, 01:08 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
