Hi I am using a Lite-On LDW 811S DVD burner to record for use on a pioneer 525 player. I am having a load of problems. I have recorded dvd5's using decrypter onto some dvd-r's and they work fine but when trying to copy any dvd9s I am having trouble. I am using a dvd+rw at the moment so I don't make coasters - I have tried using decrypter then shrink then nero, shrink on its own then nero, autoshrink iso, and have used different versions of nero thinking that was the problem. I have tried using the dvd-r's to copy dvd9's but they have the same problem.
I have tried using all different methods mentioned on the forums for nero but nothing seems to work the dvd loads up fine in the player but either freezes on the menu or into the film. Does anybody have any ideas what this could be or any similar experience with similar equipment? Any ideas would be greatly appreciated.
Chris
have you tried different media? have you tried different burning software. it could be a lot of things. make sure dvddecrypter is in file mode.
PS i wouldnt use all capital letters on your post, it really pisses some people off, its considered yelling
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Filters needed
By demonwarrior in forum Newbie / General discussionsReplies: 14Last Post: 9th Jul 2008, 07:06 -
Hack needed
By chisholmh1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Dec 2007, 10:32 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30 -
Code Needed
By dbanga in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Jun 2007, 12:22
