My sources are avi or mpeg1. In the past I have always burnt them to VCDs. I am wondering if I convert them to DVDs, would I see significant improvement in the quality?
I thought that DVD would provide better quality than VCD but some people have told me that 'what goes in is what goes out', so I shouldn't get any better quality if my sources are not DVDs. Can someone please verify. Is it worth converting them to DVDs, or shall I strick to VCDs?
Thank you.
If your video source is better than VCD then you may try DVD or else it isn't that useful. Remember that you can also use vcd/svcd quality on a dvd, low resolution and low bitrate and you will fit several hours /dvd.
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 03:25 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 02:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
