I have Dazzle DVC 80 and am using VirtualDub and i can't set the resolution to anything higher than 320 x 240.I tried to set it with the custom format but that didn' work.
I wanna capture video in 352 x 240, YUY2 or RGB24... you know all the NTSC stuff and burn to vcd but I just can't get the resoultion right but everything else (fps, audio, etc....) is good. What can i do?!?...
Big_Jit
Capture at that then resize the file afterwards
An esay solution that shouldn't affect quality too badly if you're carful.
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 01:10 -
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 20:45 -
how to convert ntsc to pal without changin the resolution?
By Remyisme in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2009, 17:30 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 19:15 -
PAL is bigger resolution than NTSC....?
By snadge in forum Newbie / General discussionsReplies: 17Last Post: 19th Jan 2008, 12:18
