I burned a VIDEO_TS folder (i made an image of it with dvd imager) and it plays fine in my cinevision dvd player, but it doesnt play on my yamaha dvd player (the one included in the yht-900 htib). Any ideas? Thoughts? Something? Thanks
-r or +r medai?
does the player support this media type?
use the DVD PLAYERS tab of the left hand column here under OTHER to see what media types is supports. -
more specifics on the yamaha player....
do you know for a fact it supports -r media?
can you put the dvd into your mac and take a screenshot of the contents of the dvd?
you need to ensure that you made the image properly so that the format of the dvd is proper (otherwise it may not playback on all dvd players)
Should be on this order
(---- implies a fodler with in the dvd)
(*** implies files within a folder)
DVD_NAME
----AUDIO_TS
----VIDEO_TS
*****VIDEO_TS.IFO
and so on....
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
No Video_TS Folder..
By NatalieR in forum ffmpegX general discussionReplies: 1Last Post: 5th Feb 2008, 10:53 -
Burn an already authored DVD-Video folder(VIDEO_TS)
By jain30 in forum Authoring (DVD)Replies: 2Last Post: 12th Jul 2007, 09:02 -
Is it better to burn a VIDEO_TS folder or a MPG file?
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2007, 16:54
