Hello!
I have 3 mpeg files with AC3 audio. When I try to join them into one big file with TmpgEnd the audio stream is "lost" somehow..... why?
TMPGEnc doesn't support AC3 audio.
Then how can I join those mpeg parts? Or how can I join the ACS files? I am really desperate here because I need to get this 3 part Xvid movie onto one dvd... the problem is the AC3 audio....
you could join all 3 parts as Xvid first with a tool like Virtual Dub. thats probably the easiest method. then rip the audio to wav with Vdub and use the wav file in TMPG along with the movie file to convert the whole thing to Mpeg2
oh and you can also just not worry about joining them and just author the DVD with three tracks that play one right after another. you shouldn't even be able to tell if it works correctly. from what I've heard trying to join audio like that can cause sync problems.
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 21:28 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 22:52 -
can't play mpeg2 w/ ac3 audio
By jlatenight in forum Software PlayingReplies: 4Last Post: 14th Feb 2009, 16:58 -
Joining MPEG2 files with different AC3 audio delay on each file
By Killer3737 in forum EditingReplies: 6Last Post: 28th Oct 2008, 00:32
