Thank you for the step by step help for capturing.
Believe it or not, I really have read quite a bit on the site, but when you're a total newbie, sometimes you don't even know what you need to read. Your blow by blow was just what I needed to get started. I successfully captured and authored my first full length movie from VHS to DVD.
I am having another problem though. Serveral movies I've tried have copy guard and it I don't know how to get around it. Is there a tool for this?
Thanks again overloaded_ide.
And thanks to all of you who have helped the dummy get started. This is a great site.
Check out the post I started below. You might get some help there.Originally Posted by Leoslocks
you'll need a hardware tool most likely. check facetvideo.com for the clarifier. it'll go inline between the VHS deck and your capture device and remove all protections.
How do I get constructive criticism without breaking the rules?
By takearushfan in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 14:23 -
Fairuse Wizard settings - looking for rules of thumb
By JamesNG in forum DVD RippingReplies: 3Last Post: 29th Jul 2008, 21:01 -
FCC adopts new Rules regarding Cable TV
By SmokieStover in forum Latest Video NewsReplies: 17Last Post: 15th Sep 2007, 04:08 -
Tighter hiring rules decried
By Heywould3 in forum Off topicReplies: 8Last Post: 16th Aug 2007, 09:42
