I created a menu background in Photoshop and added some text in the trial version of Adobe Encore.
After viewing this in my standalone DVD player, the text was shaky.
Should I be using smooth or crisp fonts when creating the menus. Or was this caused by something else?
Smooth or bold text would be better, but more than likely the text was too thin or the too much contrast. Sometimes when you use pure white text on pure black background, you end up with a little flicker. If that's what you did, you may want to try 10% gray text.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I used a smooth mid-light grey font on a very dark grey background so there wasn't much contrast.
I will try a bolder font as you suggested.
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 17:08 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 06:14 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
